Surface Texture Fill in GDL
Is there a way to use surface texture fills in GDL? I'm guessing not, since objects saved from these fill elements display cover fills instead, but I'm hoping I've missed something.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
3 Replies 3
runxel
Sadly not. I mean, someone at least managed to invest the time to provide us with a nice error message that surface texture fills will not preserved on saving. 😠
Should have used that time to implement the functionality instead, but no, let's widen the gap between all tools furthermore!
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Thanks runxel. Disappointing but not surprising; lack of surprise also disappointing.
James Murray
runxel
Just found out the issue goes on... Materials defined in GDL are also not shown...
So GDL is again left behind.
