Transfer Building materials' fill attributes to Sections/Elevations and plan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-04-17
05:56 PM
‎2022-09-26
10:56 PM
Daniel Kassai
BUILDING_MATERIAL build_mat BLOCK A, B, ZZYZXThen create a section passing trough my object, shouldn't I see the block filled with the same fill that is set for the building material?
All I see is an 'air space' fill, no matter what building material I set to the object.
Also, how could I use this same fill in plan, combined with PROJECT2{*} function?
Solved! Go to Solution.
- Labels:
Library (GDL)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-10-05 02:50 PM - edited ‎2022-10-05 02:53 PM
This should work. Be sure to turn off Floor Plan and Section > Cut Surfaces > Override Object's Attributes, and use Cut Fill in Section Setings > Model Appearance > Cut Elements > Cut Fill.
Use REQUEST{2} ("Building_Material_info") to get the fill index.
Software Engineer, Library
Graphisoft SE, Budapest
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-08-17 05:34 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-08-17 06:53 AM
Pull the Fill of your Building Material then insert it into the gs_fill_type parameter?
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
