Archicad 26 for Apple Silicon – Tech Preview launch
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2022-07-28 04:50 PM - edited 2023-05-09 10:44 AM
Have you heard the news? Tech Preview for Archicad 26 Apple Silicon version is out! Check the news on Graphisoft Insights.
What is your experience with this version? Let us know!
Noémi Balogh
Community Expert, Admin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-15 09:50 AM
@archislave, I answered a similar question in another thread (it is not planned to release a Universal Binary), please find it here: https://community.Graphisoft.com/t5/Setup-License-forum/Archicad-26-Separate-versions-for-Apple-Sili...
Senior Product Manager, BIMcloud
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-14 06:31 AM
Archicad 26 Intel version and Apple silicon Technical Preview version both crashes, when rendering process is going on and we press F5 key to move to 3D window tab, while rendering window tab is active.
Moreover, I feel like Archicad 26 rendering is substantially slower than Archicad 25.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-14 10:05 PM
Any crash should be reported to your local technical support so that it gets quickly reproduced and added to the pipeline for a bug fixing update. Hopefully the crash reporter appears when this happens? If so, be sure to share the ID with your tech support case.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-18 09:53 PM - edited 2022-08-18 09:54 PM
Can you confirm there are no incompatibilities with Teamwork projects when Apple Silicon, Apple Intel, and Windows users access the same teamwork project?
Principal, MG Architects
MacBook Pro M1 Max, 64GB
AC 6.5-27
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-18 10:00 PM
The silicon version is a higher build number. Normally if you have teamworked a file and someone opens it in a higher build number then no one else can open it unless they also update to the higher build.
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-22 06:36 PM
Is Grasshopper Connection plug in Available for Apple Silicon Version?
The last version available seams for Intel. I tried to install it but it doesn't work.
https://www.archiradar.it/en/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-23 03:23 AM
It will be (or should be) with the proper release version later this year.
Remember, this is just a Tech Preview version at the moment.
If I have been following other posts correctly, all add-ons need to be compiled specially compiled for the ARM version.
See 3rd dot point in Boldizsar Vermes post ...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-25 12:40 PM
I've tested AC26 Apple Silicon vs AC26 intel side by side with some projects and I have to admit it's blazing fast in almost every task: redraws, pan, section generation, opening app and files etc... It lacks some functions but it's very very promising.
This version opens some wet dreams like run Archicad on M1 iPads, but step by step.
This is the way
ARCHICAD 25 SPA
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-27 07:30 PM
When viewing Favourites in List View, the option button (three dots) is very difficult to select. It only seems to be clickable on the very right hand edge.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-31 11:32 AM
Thanks for reporting, we will investigate this issue.
Regards,
Gyuri
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-27 08:36 PM
Possible bug report:
When switching to another app and then back to AC, selecting items with the arrow tool is inconsistent - like the arrow location and the element(s) being selected are not in the same location on screen.
Send & receive fixes it.
AC 6.5-27
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-27 08:58 PM
Does the cursor also sometimes change to the pipette or injector? This and random zoom
is a known issue. I believe the zoom issue has been fixed in the latest update which has been released for preview and will form part of the office silicon release.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-27 09:27 PM
Yes, I believe it does. Is the updated preview release available for download?
AC 6.5-27
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-27 09:44 PM
Not for silicon. Only the AC26 Update 2 is available for Intel. There are some great improvements and additions.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-31 11:29 AM
Regards,
Gyuri
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-31 12:55 PM - last edited on 2022-08-31 07:40 PM by Karl Ottenstein
What I've seen is that when switching back AC does not get focus (sometimes it loses it too) so you cannot click or zoom even though AC is the frontmost app.
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-31 05:30 PM - last edited on 2022-08-31 07:41 PM by Karl Ottenstein
I am not sure if this is specific to the Silicon version or not but I have just opened a DWG of surveyors data in the Silicon version of 26. I have edited it and purged as I need to in order to copy in to my live model. When I copied the data and pasted across to the current Intel build of AC26 I was presented with the dialogue noting that some data was located on layers which were locked or switched off. I told Archicad to show the relevant layers and accepted the dialogue to paste the data. Half the data then appeared to be missing. It turns out that the layers some of the data was placed on were not switched on as per the option selected in the dialogue box. When I activated the Layers dialogue palette and interrogated the relevant layers, they were hidden. I showed them and the data appeared.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-01 01:43 AM
when I try to reposition editing plane in 3d window using ‘snap to story’, it is not working. However, I am able to reposition it to default location.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-14 05:05 AM
Just bumping up this thread. It would nice to have more impressions of how the preview is working out for users who are trying it out. Any feedback on speed related improvements will be greatly appreciated.
+ core i7 4970k Hackintosh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-14 05:51 AM - edited 2022-09-14 05:52 AM
I would say the improvement in speed in comparison to intel version of Archicad 26 Is roughly 25-30%. It is quite noticeable everywhere. Regeneration of sections & Elevations are quite fast. 2d and 3d navigations are buttery smooth.
In comparison to windows version, I would say it is at par, if not more, when compared to 10th or 11th gen intel pcs with same amount of RAM. But remember I am comparing my MacBook Pro M1 Max to Desktops.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-14 12:14 PM
Preview is working OK, main issue is that it has all the bugs from the Release Candidate (2 revisions ago) so it is not usable for production.
AC28 US/INT -> AC08
another Moderator
