Getting started
Read introductory articles about Graphisoft products, new features, and improvements.
Articles
New Home Screen in Archicad 28
When you open Archicad for the first time, you will notice the new and improved Home Screen. Here you have access to all the resources you need, from your recent projects to learning materials. This initial screen was designed to be your central hub,...
Home_Screen_Home.png Home_Screen_Recent.png Home_Screen_Learn.png Home_Screen_Cover.png
Quick Tutorials in Archicad 28
In Archicad 28 a new onboarding feature was created specially with new users in mind. Archicad Tooltips with embedded Quick Tutorials provides clear, concise descriptions of each tool and feature, helping you understand how they work. Hover cursor ov...
Shell_Tool_Tooltip.png Shell_Tool_Coach_Mark.png Help_Menu_Hide_Learning_Content.png New_in_Archicad.png
How to redeem a Graphisoft Learn coupon
Clients with Graphisoft Forward have free access to recorded training of the Graphisoft Learn portal. In this article, you will learn how to use the FORWARD benefit coupon on Graphisoft Learn. FORWARD coupons are for Forward customers, based on their...
Learn Voucher 1.png Learn Voucher 2.png Learn Voucher 3.png Learn Voucher 4.png
Archicad Sample Projects
Table of Content M2V House⎮residentialGino 16⎮commercial, interior designStacked Tower⎮residential, large-scaleVilla Patio⎮residentialHillside House⎮residentialS-Office⎮officeHow to start exploring the Sample Projects?What's inside the Sample Project...
Archicad Basics Series
Table of Content Sample ProjectsNavigationPlace, Select and Edit ElementsInput and Drafting AidsMoving Elements If you are new to Archicad we have two series of articles for you to help you get started: Archicad Quick Tour and Archicad Basics. The Ar...
How to Lock/Unlock Elements in ARCHICAD
Types of Element Locking Layer - When a layer is locked, all elements on the layer are locked. Individually - Elements can be individually locked independent from the locking status of their layer. How to Identify Locked Elements Locked elements cann...
wp-content_uploads_2018_10_locked_unlocked_element_in_ARCHICAD-1.png wp-content_uploads_2018_10_info_tag_locked_element_in_ARCHICAD-e1540916647675.png wp-content_uploads_2018_10_info_tag_locked_layer_in_ARCHICAD-e1540916665590.png wp-content_uploads_2018_10_layer_locked_in_ARCHICAD.png
What is BIM?
This article is a part of a series titled Archicad Quick Tour. The base of BIM (Building Information Model) is a digital 3D model of the building. It consists of walls, slabs, roofs, doors, windows and such, just like the real building. In BIM we als...
How to draft 2D Elements in Archicad
Each Archicad project is a complex database consisting of the following items: 3D design elements: walls, columns, windows and doors, MEP system elements, etc. 2D drafting and documenting elements: lines, arcs, circles, fills, texts, labels, dimensio...
wp-content_uploads_2019_10_ACE_Ch02_M01_units.png wp-content_uploads_2019_10_ACE_Ch02_M01_UnitInput.png wp-content_uploads_2019_10_ACE_Ch02_M01_line-tool-2.jpg wp-content_uploads_2019_10_ACE_Ch02_M01_GeometryMethods.png
How to draft Arcs and Circles in Archicad
The Arc/Circle Tool To explain the different methods of how to create an arc, we now change to the Arc/Circle Tool. This tool includes two main Geometry Methods: Arc/Circle Ellipse. If you click on the icon and hold the left mouse button down, you ca...
wp-content_uploads_2019_10_ACE_Ch02_M01_arc-circle.jpg wp-content_uploads_2019_10_ACE_Ch02_M01_circle.jpg wp-content_uploads_2019_10_ACE_Ch02_M01_circle-drawing-geometry.jpg wp-content_uploads_2019_10_ACE_Ch02_M01_circle-drawing3-1.jpg
How to Select Elements - The Arrow Tool
In this article, you can learn how you can select one or more elements in 2D and what methods are available to do this. Table Of Contents What Selection Looks Like The Arrow Tool Selecting a single element Deselecting elements Selecting Multiple Elem...
wp-content_uploads_2019_11_ACE_Ch02_M05_wall_preselection.png wp-content_uploads_2019_11_ACE_Ch02_M05_wall_selection.png wp-content_uploads_2019_11_ACE_Ch02_M05_Magnit.png wp-content_uploads_2019_11_ACE_Ch02_M02_selection.png
How to Select Elements - The Marquee Tool
To edit or delete elements in Archicad, you must first select them. Methods of Selection in Archicad You have two ways to select elements: you can click on the element - use the Arrow Tool you can define an area around the element - with the Arrow To...
wp-content_uploads_2019_10_ACE_Ch02_M07_Marquee.png wp-content_uploads_2019_10_ACE_Ch02_M06_Marque-1.jpg wp-content_uploads_2019_10_ACE_Ch02_M06_remove-marque.jpg wp-content_uploads_2019_10_ACE_Ch02_M06_marque-in-3d.jpg
How to Display and Select Elements in 3D
The Visibility of Elements in 3D There is a variety of different settings that affect the 3D View.At View > Elements in 3D View there are four command that help you control what is visible in 3D: Show Selection/Marquee in 3D Show Stored Selection/Mar...
wp-content_uploads_2019_10_ACE_Ch02_M07_navigation_3d.png wp-content_uploads_2019_12_ACE_Ch02_M07_filter-dialog.png
How to Edit Archicad Elements?
In this article you can learn how to: make changes to elements you created before make changes to multiple elements at once change line types, pens and colors change the reference line position of walls Changing / Editing Elements To change existing ...
wp-content_uploads_2019_12_AEC_Ch02_M08_attributes-ac.png wp-content_uploads_2019_10_ACE_Ch01_M08_selected-line2.png wp-content_uploads_2019_10_ACE_Ch02_M08_selected.jpg wp-content_uploads_2019_10_ACE_Ch02_M08_dashed-line.jpg
Drag/Rotate/Mirror an Element as Copy
You can also use all the moving commands to move an element copy. The commands work the same with the difference that the original element remains in place. The first option to invoke a copying command is via Edit > Move > Drag/Rotate/ Mirror a Copy....
wp-content_uploads_2019_10_ACE_Ch04_M03_drag-and-copy03.jpg wp-content_uploads_2019_10_ACE_Ch04_M03_Move-drag-copies02.jpg
Start Working in Archicad
This article will help you learn the basics you need to know before starting to work in Archicad. This article is a part of a series titled Archicad Quick Tour. Starting Archicad The startup dialog of Archicad: Start Archicad How to start a new proje...
wp-content_uploads_2018_11_ARCHICAD_interface-1024x617.png wp-content_uploads_ac21_help_01-configuration_EmbeddedLibrary-300x280.png wp-content_uploads_2018_11_office_layout_ARCHICAD_object.gif
How to save your work in Archicad?
This article is a part of a series titled Archicad Quick Tour. In Archicad it is important to save your work regularly. Read this article below to learn how Archicad ensures data safety. Save your work Use the 'Save' command in File menu. For the fir...
wp-content_uploads_2018_11_file-types-300x126.png wp-content_uploads_2018_11_pln-150x150.png wp-content_uploads_2018_11_pla-150x150.png wp-content_uploads_2018_11_bpn-150x150.png
Archicad Basic Concepts - The Navigator
This article is a part of a series titled Archicad Quick Tour. What is the Navigator? The Navigator Palette (Navigator) is a tree structure that lets you build up the entire logical structure of your project and navigate within it. The Navigator is d...
wp-content_uploads_2019_12_Navigator_P_V_L_P-scaled.jpg wp-content_uploads_2019_12_Workflow-scaled.jpg wp-content_uploads_2019_11_Show-Navigator-Project-Chooser.png wp-content_uploads_2019_11_Show-navigator-Right-click.gif
The Archicad interface
TABLE OF CONTENTS The Archicad interfaceThe Tab BarThe ToolboxThe Menu BarThe ToolbarsThe Info BoxPalettesCustomize Archicad's interface If you have not yet installed Archicad, read this article to learn how to proceed with the installation. Open Arc...
Elevating Elements
The “Elevate” command allows you to move selected elements vertically along the Z-axis. Elevating in the Floor Plan Once more, you first must select the element.Then, invoke the “Elevate” command via Edit > Move or from the pet palette. This brings u...
wp-content_uploads_2019_10_ACE_Ch04_M04_Page_1_Image_0001-1.jpg wp-content_uploads_2019_10_ACE_Ch04_M04_elevate02.jpg wp-content_uploads_2019_10_ACE_Ch04_M04_elevate003.jpg wp-content_uploads_2019_11_ACE_Ch04_M04_Elevating.jpg
Mirroring Elements
Mirroring creates a mirror image of the selected elements. Select the elements you want to mirror. Invoke the command via Edit > Move > Mirror … or select it from the context menu or the Pet Palette. Define the mirroring axis with two clicks, as if y...
wp-content_uploads_2019_10_ACE_Ch04_M03_Mirror03.jpg wp-content_uploads_2019_10_ACE_Ch04_M03_mirror001.jpg
Rotating Elements
The “Rotate” command allows you to rotate elements around a freely selected rotation center. Just as at the “Drag” command, you first must select an element. Check How to Select Elements - The Marquee Tool , also How to Select Elements - The Arrow To...
wp-content_uploads_2019_10_ACE_Ch04_M02_Rotate.jpg wp-content_uploads_2019_10_ACE_Ch04_M02_Rotate003.jpg wp-content_uploads_2019_10_ACE_Ch04_M02_Rotate004.jpg wp-content_uploads_2019_10_ACE_Ch04_M02_Rotate005.jpg
Moving Elements
Editing existing elements is an essential every-day task. Basic Rules The element you want to edit MUST be selected BEFOREHAND. Only then will relevant commands will be available. You can edit elements on the Floor Plan as well as in the 3D window. N...
wp-content_uploads_2019_10_ACE_Ch04_M01_move-command-1.jpg wp-content_uploads_2019_10_ACE_Ch04_M01_move-options.jpg wp-content_uploads_2019_10_ACE_Ch04_M01_line-moving.jpg wp-content_uploads_2019_10_ACE_Ch04_M01_Wall-selected.jpg
Get to Know Doors and Windows
In Archicad Doors, Windows and Objects are prepared for you and stored in small files that are organized in folders called libraries. The prepeared Doors and Windows are parametric objects which means you are able to change their hight, width and man...
wp-content_uploads_2019_10_ACE_Ch03_M07_door-icon.jpg wp-content_uploads_2019_10_ACE_Ch03_M07_anchor-point01.jpg wp-content_uploads_2019_10_ACE_Ch03_M07_placment.jpg wp-content_uploads_2019_10_ACE_Ch03_M07_opening003.jpg
Navigating in the Project
Navigation in the ProjectThe Structure of the ProjectThe Pop-Up Navigator and the NavigatorTabs and the Tab Bar When talking about navigation, we need to address three different things: navigation in the project itself navigation in 2D navigation in ...
wp-content_uploads_2019_10_ACE_Ch01_M03_StartupDialogEmpty.png wp-content_uploads_2019_10_ACE_Ch01_M03_browse_open.png wp-content_uploads_2019_10_ACE_Ch01_M03_ReadElements.png wp-content_uploads_2019_10_ACE_Ch01_M03_floorplan2.png
Magic Wand
There is a special function in Archicad called “Magic Wand”. This function saves you work by finding and tracing a linear or polygonal shape from among existing elements and then generating a new element based on it. Magic Wand can be used in 2D and ...
wp-content_uploads_2019_10_ACE_Ch03_M04_outline-Magic-wands.jpg wp-content_uploads_2019_10_ACE_Ch03_M01_MAGIC-Wand-1.png wp-content_uploads_2019_10_ACE_Ch03_M01_MAGIC-Wand2.png wp-content_uploads_2019_10_ACE_Ch03_M01_MAGIC-Wand3.png
Snap References
If you want to find for example the midpoint of an existing element or you want to place a new element parallel to another one, use the Snap References. Snap References are temporary lines, arcs, and points that appear along with existing elements, t...
wp-content_uploads_2019_10_ACE_Ch03_M02_snap.jpg wp-content_uploads_2019_10_AEC_Ch03_M02_wall-snap.png wp-content_uploads_ac21_help_02-interaction_UserOriginSnap00021.png wp-content_uploads_2019_10_ACE_Ch03_M02_Devision.jpg
Guide lines
Guide Lines are drafting aids, which help you find special points and projections, to ensure precise input in both, 2D and 3D windows. Unlike Snap Guides, Guide Lines are explicitly placed by you. They always remain in place until you remove them. Gu...
wp-content_uploads_2019_10_ACE_Ch03_M01_Creating-Guide-Lines.jpg wp-content_uploads_2019_11_ACE_Ch03_M01_guidelines.png wp-content_uploads_2019_10_ACE_Ch03_M01_create-guide.jpg wp-content_uploads_2019_10_ACE_Ch03_M01_Creating-Guide-Lines-segment.jpg
How to Model Walls in Archicad
To be able to practice what is discussed in this article, it is best if you start a new project. Go to The Archicad Interface to learn how to start a new project. The Wall Tool Walls are one of the basic construction elements in Archicad. You can cre...
wp-content_uploads_2019_10_ACE_Ch02_M03_Wall-tool.jpg wp-content_uploads_2019_10_ACE_Ch02_M03_gemotry-methods.jpg wp-content_uploads_2019_10_ACE_Ch02_M03_gemoetry-options.jpg wp-content_uploads_2019_10_ACE_Ch02_M03_geometry-options-2.jpg
Navigating in 2D
When talking about navigation, we need to address three different things: navigation in the project itself navigation in 2D navigation in 3D In this article, you will learn how to navigate in the 2D views (such as floor plans, sections, elevations an...
wp-content_uploads_2019_10_ACE_Ch01_M03_StartupDialogEmpty.png wp-content_uploads_2019_10_ACE_Ch01_M03_browse_open.png wp-content_uploads_2019_10_ACE_Ch01_M03_ReadElements.png wp-content_uploads_2019_10_ACE_Ch01_M04_touchpad_wicons.jpeg
How to Use the Find and Select Tool
In this article you can learn how to: Search for, find, and select elements that fulfill specific criteria or multiple criteria Store the groups of criteria as Criteria Set to use later How to Find and Select You can select multiple elements at once,...
wp-content_uploads_2019_10_ACE_Ch02_M09_find-and-select-2.jpg wp-content_uploads_2019_10_ACE_Ch02_M09_find-and-select.jpg wp-content_uploads_2019_10_ACE_Ch02_M09_find-and-select-type.jpg GiovanaBenvenuto_0-1666783114117.png
Setting up Grids in Archicad
In Archicad there are two different kinds of grid systems that help you while modeling and drawing. The Construction Grid The Snap Grid. Using them is optional, you can work in Archicad without using any grid, but in specific circumstances, they are ...
wp-content_uploads_2019_10_ACE_Ch02_M04_Grids.png wp-content_uploads_2019_10_ACE_Ch02_M04_Grid-tool.jpg wp-content_uploads_2019_10_ACE_Ch02_M04_Construction-grid.jpg wp-content_uploads_2019_10_ACE_Ch02_M04_Customized-grid.jpg
How to Use the Smart Cursor in Archicad
The cursor changes its shape(s) as you work giving you accurate feedback on: where the cursor is and whether an editing or input operation is going on or not. The shape of the cursor sometimes also depends on which tool (Arrow Tool, Marquee Tool, Wal...
wp-content_uploads_2019_10_ACE_Ch02_M03_Cursor-Symbols_2d_modified.png wp-content_uploads_2019_10_ACE_Ch02_M02_cursor-1st-1.png wp-content_uploads_2019_10_ACE_Ch02_M02_cursor-2nd.png wp-content_uploads_2019_10_ACE_Ch02_M02_cursor-3rd.png
Navigating in 3D
When talking about navigation, we need to address three different things: Navigation in the project itself Navigation in 2D Navigation in 3D In this article, you will learn how to navigate in the 3D views (such as perspective and axonometry) of your ...
wp-content_uploads_2019_10_ACE_Ch01_M03_StartupDialogEmpty.png wp-content_uploads_2019_10_ACE_Ch01_M03_browse_open.png wp-content_uploads_2019_10_ACE_Ch01_M03_ReadElements.png wp-content_uploads_2019_10_ACE_Ch01_M03_navigation_summary_3D_wicons2.jpeg
Stories in Archicad
Stories in Archicad, just as in real buildings, serve to divide space vertically and replicate the story structure of your real building. Stories are ranges of height in space. Each story has a reference (level). It is the height of the horizontal pl...
Screen Shot 2022-10-26 at 17.21.52.png wp-content_uploads_2019_10_ACE_Ch02_M04_stories.png GiovanaBenvenuto_0-1666786407556.png wp-content_uploads_2019_10_ACE_Ch02_M04_stories2.png
How Walls are Connected in Archicad
For controlling the junction of the walls 4 major tools and settings are available in Archicad: Reference Line: only walls with joining reference lines will be connected. Layer Intersection Number can be used to prevent intersection. Junction Order c...
wp-content_uploads_2019_04_Walls_Reference-_lines-e1554895252805.jpg wp-content_uploads_2019_04_intersect-1024x402.png wp-content_uploads_2019_04_Walls_Layer_connections-300x187.jpg wp-content_uploads_2019_04_junction_order-1024x374.png
Archicad Basic Concepts - Libraries
This article is a part of a series titled Archicad Quick Tour. What are Libraries? They are collections of preconfigured, editable, localized parametric objects, that are also known as Library parts, GDL objects or simply objects. Libraries are actua...
wp-content_uploads_2018_11_office_layout_ARCHICAD_object.gif wp-content_uploads_ac21_help_01-configuration_AddLinkedLibrary-300x239.png wp-content_uploads_ac21_help_01-configuration_ReloadApply-300x280.png wp-content_uploads_ac21_help_01-configuration_RemoveLibrary2-300x280.png
Rotate Elements in 3D
Free rotation is available for Shells, Curtain Walls and Morphs in the 3D window, while other construction elements can be rotated only horizontally. Settings, controlling their slope or pitch vary by element type: Walls can be slanted or double slan...
wp-content_uploads_2018_12_free_rotate.gif wp-content_uploads_2018_12_editing_plane.gif
Keyboard Shortcuts
Some useful ShortcutsHow to list all the Shortcuts?How to customize shortcuts? Archicad is shipped with several predefined shortcut schemes. These can be listed and most of the shortcuts can be redefined in Options > Work Environment > Keyboard Short...
wp-content_uploads_2018_08_show_shortcut_list_in_browser-300x149.png wp-content_uploads_2018_08_trace_and_reference_shortcut-300x226.png wp-content_uploads_2018_08_currently_assigned_shortcut-300x224.png wp-content_uploads_2018_08_currently_not_assigned_to_any_command-300x181.png
