3d Modeling Glitch/model corruption
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-01-30 08:51 PM
‎2019-01-30
08:51 PM
Also, with this glitch, *nothing* shows in the 3D non-vector view unless I select objects in 2D and then show selected in 3D.
Help!
TV / Film Production: Sr. Set Designer
Art Directors Guild, Local 800
Archicad Latest Version
MacBook Pro (15-inch, 2018), 2.9 GHz Intel Core i9, >32 GB 2400 MHz DDR4, Radeon Pro Vega 20 4080 MB, Intel UHD Graphics 630 1536 MB
Labels:
- Labels:
Performance
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-01-31 03:41 AM
‎2019-01-31
03:41 AM
Additionally, when I select an object and command "move" the object, it just disappears. I have no cutting planes set up, but when I zoom out after the command, it appears, but seems to be passing through a cutting plane of some sort.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-01-31 04:36 AM
‎2019-01-31
04:36 AM
Sounds to me like a video card/driver issue.
Are your drivers up to date?
Am am no tech expert and I am not familiar with your Radeon card or if it is even suitable for Archicad.
You have that and an built-in card?
Archicad does not like those integrated cards all that much.
I am not familiar with Macs at all, but can you tell it somewhere in the settings to use the Radeon card only with Archicad?
If it is then maybe that card or its driver is not compatible.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-02-04 08:50 PM
‎2019-02-04
08:50 PM
Its an internal video driver that came with the computer. I just started having this problem within the past week or so. Prior, it was working fine. It seemed to be an import of some sketchup file that caused it to start happening, or it just started to coincidentally start happing. Any further thoughts on the matter would be massively appreciated. The particular file that I took this screenshot in however, has no imported Sketchup files, and is a brand new ac file.
I also opened both the older file and the fresh one on my older macbook, which never had this problem, and now that computer is showing the same symptoms.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-03-05 01:48 PM
‎2019-03-05
01:48 PM
I am also having the exact same problem. Not sure what has caused it though.
