AC20 slowing down with 99% proc use when auto-rebuild model
Hello
I have a problem with ArchiCad 20 that drive me crazy.
First this is my first post and I'm using AC since 6 months only... And I am not an architect, I do this for my own use and to learn sth new. So I do not use professional terms, and still do not know much about AC20.
I do believe I have a perfect hardware setup howewere the software keep slowing down to a point it almost freeze without crashing. I can leave it in this state for 20 minutes without any change.
This problem happen when I launch AC20 and go to "Elevation> Auto-rebuild model" in my project. Screenshot: http://i.imgur.com/W8RwdLW.png
The moment I do that my Computer Slow down and AC use 99% of my processor for ever, and ever, and ever....
Screenshot: http://i.imgur.com/zy6gcDM.png
AC Screen: http://i.imgur.com/rI36rHQ.png
I'm desperate
THANK U
7 REPLIES 7
If I had to guess (and that's all we can do here), is that you have a corrupt element, or you have modeled incorrectly. (e.g. http://helpcenter.graphisoft.com/troubleshooting/3d-modeling/3d-modeling-troubleshooting-guide/degen...)
The only way to track this down is very tedious. You need to progressively erase your model to find out where the corrupt element is. (Usually this is done 1/2 model at a time. i.e. erase 1/2, 1/4/ 1/8. etc.) At some point, you will like see the issue disappear, and then you know which 1/2 of what you are working on the issue is in. Or you could erase 1 layer at a time, if you don't have too many layers. Work on copies of your original, of course.
Richard
AC25 (since AC6.0), Win10
David Maudlin
Zosia:
Since your error message mentions "calculating split polygons", it could be that shadow generation is the problem. Go to the Elevation Settings > Model Display > Sun and Shadows > and uncheck "Sun Shadow". You should also look through this dialog box to see if there are other elements to disable.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC26 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.15.7
Thank you to both of you! I will try to follow your advices. I will let u know if I menage to do it ...Thank u!!!
Where is this elevations settings?;) I can't not find it for the life of me. This is a standalone settings box?
When you are in a Section or Elevation, right-click and select the Elevation Settings option to open the Elevation Settings Dialog. In the Dialog, go to the Model Display panel and uncheck the Sun Shadow checkbox and shadows will not be generated.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Ok, great; thanks. It was not checked, though;)
It didn't show up here in ArchiCAD-21 in section view, only when in elevation view. Also, there's no other way to bring up this dialog box without first opening an elevation view?;)
Sections and elevations each have their own settings.
You have to set each and every section and elevation you have.
Just right mouse click on any section or elevation in the project map or the view map of the navigator.
You will see an option for 'Section Settings' or 'Elevation Settings'.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
