AC20 slowing down with 99% proc use when auto-rebuild model
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2017-01-31 09:36 PM
2017-01-31
09:36 PM
I have a problem with ArchiCad 20 that drive me crazy.
First this is my first post and I'm using AC since 6 months only... And I am not an architect, I do this for my own use and to learn sth new. So I do not use professional terms, and still do not know much about AC20.
I do believe I have a perfect hardware setup howewere the software keep slowing down to a point it almost freeze without crashing. I can leave it in this state for 20 minutes without any change.
This problem happen when I launch AC20 and go to "Elevation> Auto-rebuild model" in my project. Screenshot: http://i.imgur.com/W8RwdLW.png
The moment I do that my Computer Slow down and AC use 99% of my processor for ever, and ever, and ever....
Screenshot: http://i.imgur.com/zy6gcDM.png
AC Screen: http://i.imgur.com/rI36rHQ.png
I'm desperate
THANK U
Labels:
- Labels:
Performance
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-02-01 01:01 AM
2017-02-01
01:01 AM
If I had to guess (and that's all we can do here), is that you have a corrupt element, or you have modeled incorrectly. (e.g. http://helpcenter.graphisoft.com/troubleshooting/3d-modeling/3d-modeling-troubleshooting-guide/degen... )
The only way to track this down is very tedious. You need to progressively erase your model to find out where the corrupt element is. (Usually this is done 1/2 model at a time. i.e. erase 1/2, 1/4/ 1/8. etc.) At some point, you will like see the issue disappear, and then you know which 1/2 of what you are working on the issue is in. Or you could erase 1 layer at a time, if you don't have too many layers. Work on copies of your original, of course.
Richard
AC26 (since AC6.0), Win10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-02-01 02:04 PM
2017-02-01
02:04 PM
Zosia:
Since your error message mentions "calculating split polygons", it could be that shadow generation is the problem. Go to the Elevation Settings > Model Display > Sun and Shadows > and uncheck "Sun Shadow". You should also look through this dialog box to see if there are other elements to disable.
David
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-02-02 03:13 PM
2017-02-02
03:13 PM
Thank you to both of you! I will try to follow your advices. I will let u know if I menage to do it ...Thank u!!!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-02-13 01:57 PM
2018-02-13
01:57 PM
Where is this elevations settings?;) I can't not find it for the life of me. This is a standalone settings box?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-02-13 09:43 PM
2018-02-13
09:43 PM
When you are in a Section or Elevation, right-click and select the Elevation Settings option to open the Elevation Settings Dialog. In the Dialog, go to the Model Display panel and uncheck the Sun Shadow checkbox and shadows will not be generated.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-02-14 12:45 AM
2018-02-14
12:45 AM
Ok, great; thanks. It was not checked, though;)
It didn't show up here in ArchiCAD-21 in section view, only when in elevation view. Also, there's no other way to bring up this dialog box without first opening an elevation view?;)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-02-14 01:39 AM
2018-02-14
01:39 AM
famadorian wrote:Sections and elevations each have their own settings.
You have to set each and every section and elevation you have.
famadorian wrote:Just right mouse click on any section or elevation in the project map or the view map of the navigator.
You will see an option for 'Section Settings' or 'Elevation Settings'.
