ArchiCAD 10 Crash on Startup
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-08-24
12:28 PM
2024-07-09
01:53 PM
Aruzhan Ilaikova
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-08-25 08:40 AM
Darrel wrote:QuickTime version? Video card?
Hi, I just loaded ArchCAD 10 on a new Dell Precision computer 4 GB RAM Windows XP Pro SP2. However it crashes on start up. The splash screen comes up then crashes. ArchiCAD 9 runs great on the computer, I have tried unistalling re-installing but nothing seems to work. Any help would be appreciated
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-08-25 11:22 AM
I am using Quicktime 7 (The one off of ArchiCAD 10 CD)
The video card is a Nividia Quadro 3450 with 256 MB of RAM, and with the latest drivers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-08-28 06:02 PM
XP Pro (SP2)
Core 2 Duo Extreme Edition (x6800)
Ram: 2 gigs DDR2-SDRAM PC2-5300
Nvidia Quadro 3450 - 256 ram (latest patch)
Quicktime 7 (latest patch)
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-08-29 12:58 AM
This only started happening after the last AC 9 update. I have AC 10 installed and haven't had the problem yet with AC 10.
Grant
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-08-29 01:32 PM
It seems we have the same computer system, I spoke to several IT guys and they all think it may be something to do with the BIOS settings, as the processors we have are new. However they can't explain why AC 9 works great but 10 does not work at all. I have sent several bug reports to Graphisoft but have not gotten any response.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-09-08 03:47 AM
If I launch a template file first and then sign in to the same teamwork project everything works fine. I get the same kernel panic (system crash) if I try to open a AutoCAD file from the same startup dialog box.
AC10 MacTel has been pretty solid once I get into the file.
Regards,
Michael
Work: MacPro
Two 2.66GHz Dual-Core Intel Xeon "Woodcrest" processors
5GB memory
NVIDIA GeForce 7300 GT graphics with 256MB memory
Home: iMac
2.0GHz Intel Core 2 Duo processor
2GB memory
ATI Radeon X1600 graphics with 128MB GDDR3 memory
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-09-08 02:05 PM
Darrel wrote:
HI Djordje
Try Changing your Default Printer to Amyuni Printer or some other. ArchiCAD always checks for the default printer while startup and if the printer drivers doesn't support it crashes at the splash screen. May be this is what happening with you. Try it and do let us know.
Srini.
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-09-16 03:16 AM
Good Luck
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-09-16 04:18 AM
dspahn wrote:Thanks for the info, tried it and ArchiCAD 10 Finally opens. What a relief, now I can start to learn 10 .
We found that the crash during the splash screen loading in AC10 on a Dell Precision 390 was caused the presence of wxvault.dll. The solution is to remove the EMBASSY software that McAfee depends on. I don't think it will disturb your AV or firewall, but it seems to disrupt the spamkiller.
Good Luck
