Installation & update
ArchiCAD 13 and the file converters
After installing ArchiCAD 13 on Mac OSX 10.5 I noticed that the file converter versions (9.0 and 7.0) stopped recognizing the protection key.
On the Windows BootCamp partition where only AC12 was installed I could get them working with a 12 key, but not with the key which has been upgraded to 13.
Has anybody had some similar problems?
I would guess that it is a WIBU driver version thing. See:
http://www.graphisoft.com/support/archicad/downloads/WIBU.html
perhaps you need to reinstall 5.20b
(For OS 10.6, the converters work with the 5.3 and the wkmac.lib listed there.)
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Excellent guess!
it worked, thank you
Glad it worked, Ferenc! 🙂
