ArchiCAD 22 Solo - Curtain Wall tool does not turn to sunshine icon to set outside of wall
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-05-10 02:15 AM
‎2019-05-10
02:15 AM
Anyone have any ideas?
I like cheese.
Solved! Go to Solution.
Labels:
- Labels:
Performance
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-05-10 03:34 AM
‎2019-05-10
03:34 AM
In 22 the placement method has changed so it is more like a wall or railing where you see the reference line and the curtain wall position as you place it.
If the curtain wall is not on the correct side of the reference line you have a 'Flip' option.
You also have panel offset options so you can choose the offset of the curtain wall away from the reference line.
Depending on the construction of your curtain wall will determine if you offset from the center of the panel or the face of the frames.
Either way you will see a preview of the wall as you place it.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-05-10
03:34 AM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-05-10 04:18 AM
‎2019-05-10
04:18 AM
Many thanks Barry. I'm trying to follow along with the Beginner online tutorial just to get started and that video must have been made with a previous version. Now that I know this info from you, it makes much more sense!
I like cheese.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-05-10 04:31 AM
‎2019-05-10
04:31 AM
If it is an older tutorial (not done for 22) then you will find the curtain wall quite different as it was changed in 22.
You can see some Youtube movies for the 22 curtain wall here.
https://www.youtube.com/playlist?list=PLnXY6vLUwlWVy5Rz3QrauRciNh7_2DDyf
