2008-06-17 09:17 PM
2008-06-18 08:34 AM
Patsurf wrote:Only AC 11.
Which versions of "out of the box" AC are now fully compatible with Vista?
2008-06-18 06:50 PM
Patsurf wrote:I have Vista and AC9 seems to work fine on it (Vista Home Premium).
I recently purchased a new laptop for personal use and for work when I go on the road. As with most laptops nowadays, they all come with Vista.
I have seen the following information/instructions on installing AC90 so it works with Vista:
Problem: ArchiCAD will not install correctly.
Solution: Uninstall Java. Re-install java that came with ArchiCAD 9. Perform a custom install of ArchiCAD which excludes Graphisoft Shell Extensions from both the ArchiCAD and the Plotmaker install. Remove Wibu installation that ArchiCAD 9 performs. You may have to uninstall and re-install Wibu 5.2 if you have already done this.
Since I am not a "tech" guru, is there a complete step-by-step instruction on how to do this somewhere? I do not know what "shell extensions" are or how to deal with the Wibu install.
Thanks ahead,
PB
P.S. Which versions of "out of the box" AC are now fully compatible with Vista?
2008-06-20 10:39 AM
