Installation & update
ArchiCAD performance regardless of hardware and drivers.
I would like to bring up the topic of ArchiCAD performance.
I noticed that work in the program with the growth of the model at some point turns into pain and suffering. At first I blamed everything on huge detailed projects, which seemed logical. I start projects with a template that works quite well at first. With the same template, I started a small project - a house of 65 m2 without unnecessary detail. Everything is expected, it works quickly, no problem! But the problems started when I started making changes to the project. I did redevelopment, I removed unnecessary things, added a new one, and by the 6th version, everything started to slow down as if I were designing another school for 1500 squares with ventilation and heating. Exactly the same symptoms: selection of an object with a delay of 2-3 seconds, long transitions from view to layout and back, for 2 minutes opening specifications of windows and doors. Selecting tools with a delay of 2-3 seconds, selecting and performing operations with objects through a pop-up menu, opening a context menu or object settings .... Everything with a delay of 2+ seconds. So, purely for understanding the volume: about 20 tuned views, 7 layouts. That's it, there is nothing else in the project!
I was puzzled and collected all the same from scratch in a standard template and default interface settings. No brakes! Modified walls windows doors roof furniture ... does not slow down!
What could be the problem?
my favorite xxx porn site https://gaypornmoviestube.com/
a lot of videos with cute twinks
Nader Belal
Mentor
Views and layouts
A good friend of mine have once told me that I´m so brute that I´m capable of creating a GDL script capable of creating GDLs.
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you for sharing the issue and I am very sorry about the experience!
From the description, it is hard to tell what may have caused this issue. I'm wondering if it is possible for you to share the file for a closer look? Please let me know if you need a secure place to upload the file also.
Thank you very much! Looking forward to hearing from you!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
