Installation & update
Archicad 12 "No Protection Key Found . . ."
I just received v12 in the mail today and tried to install in on my Mac and my PC and got the same error message "No Protection Key Found or Not Valid" when I tried to run it. I thought my key may have been bad so I tried running v11 which worked just fine. Any help would be great.
Thanks
8 REPLIES 8
Thanks
Have you upgraded the key to version 12?
There should have been instructions with the software.
Can be done via the internet if it is the same as for previous versions.
Thanks . . . I'm an idiot
vfrontiers
Is anyone else having problems upgrading via Safari on Mac? Safari just displays a blank web page when going to the upgrade.graphisoft.com website....
Worked fine on my pc.
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
Eduardo Rolon
Safari worked OK here. Just in case check that you are not blocking popup windows.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
vfrontiers
Seems my 2 Macs at work worked fine as well... Just the one iMac at home is not working. Must be a setting or something.
Just popped the wibu in the PC and all is well.
Duane
Visual Frontiers
Hi Duane,
I had a similar issue last May that I reported as defect 19624 (upgrade site would not recognize the key with Safari on 10.5)...and resolved it with GS tech support by uninstalling and reinstaling the WIBU driver after we ruled out Java and other possibilities. At that point, I reinstalled the WIBU driver from the AC 11 app folder...after running the uninstall located there.
Regards,
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
vfrontiers
Guess that's what happens when I don't get asked to participate in the Beta's anymore!
Duane (outside the loop) Valencia
Duane
Visual Frontiers
Actually, I found/reported the WIBU issue via normal channels ... but no doubt beta testing distracted me from sharing the results here.
Regards,
