Installation & update
Archicad 13 - 3D explorer bug (falling)
Please check the video screen capture i made from the bug of the 3D explorer, the cam is falling
http://www.courtens.be/archicad/bug-archicad-13.mpg 9Mb
thx for help
Archicad 13 FR
Nvidia quadro FX 1800 last drivers
Windows XP
4 REPLIES 4
If you mean that the Camera does not show anything of the Mesh when it is inside the Mesh's body: I am not sure that is a bug. Rather a feature, it has been working like that for versions.
no, the camera is just falling down continuously, like no ground.
That video is not opening for me, however, the first thing i would check is if it was a hardware issue. could the page down key be stuck?
OK, I get it now.
So you are moving in a direction and that direction suddenly changes into vertical.
There are two possibilities:
1. You accidentally pushed the keyboard shortcut for going downward. This is the C key by default in the INT version which is very close to the WASD keys used for navigation. The reason I think this may be the case is because in the video the camera was moving downward at your first attempt, but not moving at the second.
2. It is really a bug. If you think that is the case you should report it to your local reseller.
