Archicad 23 not showing anything
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-01-11 06:25 PM
‎2021-01-11
06:25 PM
My system:
OS: Windows 10 Home 64.bit
CPU: Intel(R) Core(TM) i7-6700HQ CPU @ 2.6GHz
RAM : 16GB
GPU 0 : Intel(R) HD Graphics 530
GPU 1 : NVIDIA GeForce GTX 970M 3GB
Solved! Go to Solution.
Labels:
- Labels:
Performance
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-01-12 08:46 PM
‎2021-01-12
08:46 PM
In the graphics setting it is possible to select the dedicated graphics card for your application. It is known from Graphisoft that integrated graphics chips are not recommended for Archicad.
Try to do the above and see if that helps. You may have to restart Archicad for the change to take effect.
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-01-12
08:46 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-01-15 11:38 AM
‎2021-01-15
11:38 AM
It worked, thank you.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-09-18 10:17 PM
‎2022-09-18
10:17 PM
What did you do please im facing the same problem
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-09-18 10:31 PM
‎2022-09-18
10:31 PM
As @Laszlo Nagy recommend to install your graphic card which is suitable to Archicad rather than relying on the built-in one.
AC 28 INT 3110/WIN 11
