Archicad 24 won't start
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2020-11-11
02:59 PM
ā2024-01-29
02:10 PM
Aruzhan Ilaikova
I've installed the Archicad 24 as a Student version, still the program won't start, the cursor shows a loading signal for a while, it's starting though as a background process as an Archicad Component, but still the program is not starting.
i've updated my Windows to the latest version of Windows 10.
what can be the problem ??
working on an: Intel i7-8700 3.20GHz
16.0 GB RAM
Nvidia 1060 TI
- Labels:
Install & Update
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2020-11-16 02:28 PM
Thank you very much for the question and I am very sorry about the issue!
First, I would like to make sure that all GPU drivers are up-to-date. Please follow the links below to make download the latest version for each component:
- Intel integrated GPU:
- NVIDIA: https://www.nvidia.com/Download/index.aspx
If after installing these 2 drivers Archicad still refuses to run, I'm wondering if there is any active Firewall/Antivirus software? They could block the license checking process at startup, preventing AC from starting up.
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2021-01-08 07:44 PM
Š”ŃŠ¾Š»ŠŗŠ½ŃлаŃŃ Ń ŃŠ°ŠŗŠ¾Š¹ же ŠæŃоблемой. Š£ŃŃŠ°Š½Š¾Š²ŠøŠ»Š° Archicad 24 как ŃŃŃŠ“ŠµŠ½ŃŠµŃŠŗŃŃ Š²ŠµŃŃŠøŃ. ŠŠ°ŠŗŠ¾Šµ ŃŠ¾ Š²ŃŠµŠ¼Ń ŠæŃŠ¾ŃŠ°Š±Š¾ŃŠ°Š» Šø ŠæŠµŃŠµŃŃŠ°Š» запŃŃŠŗŠ°ŃŃŃŃ. РоГной Š±ŃанГмаŃŃŃ Š¾ŃŠŗŠ»ŃŃŠµŠ½. Š”ŃŠ¾ŃŠ» ŠŠ½ŃивиŃŃŃ Avast. УГалила. ŠŃоблема не ŃŠµŃилаŃŃ. ŠŠ¾ŃŃŠ°Š²ŠøŠ»Š° NOD32, в ŠæŃŠ°Š²ŠøŠ»Š°Ń ŃŠ°Š·ŃŠµŃŠøŠ»Šø ŠæŠ¾Š»Š½ŃŠ¹ ГоŃŃŃŠæ Š“Š»Ń Archicad 24, ŃŠ°Šŗ же не помогло. Š§ŃŠ¾ ГелаŃŃ?
Windows 10
Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
NVIDIA GeForce GTX 1650 (ŠŃŠ°Š¹Š²ŠµŃŠ° ŃŃŃŠ°Š½Š¾Š²Š»ŠµŠ½Ń ŠæŠ¾ŃŠ»ŠµŠ“ние)
ŠŠæŠµŃŠ°Ńивной 16,0 ŠŠ
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2021-01-10 02:49 PM
Hello.KATERINA, requirement for posting is to use english.
Faced the same problem. Installed Archicad 24 as a student version. I worked for a while and stopped starting. The native firewall is disabled. There was Avast Antivirus. Deleted. The problem was not solved. Delivered NOD32, allowed full access for Archicad 24 in the rules, it also did not help. What to do?
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2021-01-10 04:59 PM
ejrolon wrote:Thank you!
Translation,Hello.KATERINA, requirement for posting is to use english.
Hello!
Faced the same problem. Installed Archicad 24 as a student version. It worked for a while and stopped running. The native firewall is disabled. There was an Avast Antivirus. Deleted it. The problem was not solved. Put NOD32, the rules allowed full access for Archicad 24, also did not help. What to do?
Windows 10
Intel (R) Core (TM) i3-9100F @ 3.60 GHz Processor
NVIDIA GeForce GTX 1650 (Latest drivers installed)
16.0 GB of RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2021-01-13 09:29 AM
Thank you very much for the question!
I only understand the translation version, so I hope everything is correct
Could you let me know in detail what happens when you start Archicad? You mentioned that "It worked for a while and stopped running". Do you mean Archicad can start and load the Work Environment and project plan, and stop running while editing the project file, or Archicad cannot even start after clicking New/Browse?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2021-01-13 10:35 AM
Yes, Archicad can't even start working after pressing the button. I can't start and load the working environment and project plan at all. Video in the attached file.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2021-01-13 10:53 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2021-01-13 10:59 AM
Thank you very much for the video!
Usually, if Archicad can start, there must be a splash screen showing up with Archicad logo and its signature. Have you tried to completely uninstall, then reinstall Archicad?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2021-01-13 11:35 AM
