Installation & update
Archicad 25 4013 freezing the whole system when starting
amgam
I installed the update hoping it would fix the common "explosions" of Archicad 25 (quitting). Not only did it not help, but now the whole system (Mac OS Big Sur 11.2.3) freezes completely whenever Archicad opens a file. Attaching the system info here:
I'm sure this is not just Archicad but also the ever-worse Mac OS, which at this point has reached the levels of Windows when it comes to degradation.
Hope this is resolved soon.
ArchiCAD 25 FRA 3011 + TwinMotion 2021.1.4
iMac Retina 27 2020 3,8 GHz Intel Core i7 8 cœurs
64 Go 2667 MHz DDR4
AMD Radeon Pro 5700 XT 16 Go
6 REPLIES 6
Dave Jochum
I don't think it's Big Sur, but AC 4013 update 2. I'm having many issues in AC since update 2 and none in any other software. Surfaces are losing their definitions, elevations are randomly changing settings--several others. Very frustrating. I'm running the latest OS version 11.6.1. These issues are worse than the more minor glitches reported in Monterey. New M1 Max on the way.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 13.2.1•AC 26 Silicon (latest build)
@amgam Why are you running the very old Big Sur 11.2.3 and not the most recent 11.6.1 update?
@Dave Jochum Disappointed to read you're experiencing issues too. Hope you have reported this?
One of the forum moderators
AC 26 USA and earlier   •   macOS Ventura 13.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Dave Jochum
Yes, I just did Karl.
Dave Jochum
Dave Jochum
Graphisoft called back quickly, but I was not available to take the call. The tech had several suggestions which I will try. Kudos to Graphisoft. I will post here when I figure it out.
Dave Jochum
Isn't my post the answer? I only updated Archicad as the original installation of 25 didn't run smooth and had many problems, especially AC turning off few times a day, (crash).
I don't update often because these updates usually do more bad than good.
64 Go 2667 MHz DDR4
Virgil_1
Update two is not sufficient by itself; you will also need to be running macOS 11.3 or greater. Try it...
