Archicad 25 on Mac Lagging
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2022-01-19 10:22 PM
Hi. I have problem with Archicad when Trace & Reference is on. I am using MacBook Pro M1 Max with 64 gb memory. The performance supposed to be good, but I can’t even start to draw because of this lag, mouse not even moving on the screen. Is there any way to solve it?
thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-20 04:00 PM
Thank you very much for the report and I am very sorry for the experience!
When the slowness happens, is it intermittent or it will always happen with Trace & Reference active? Does it happen on a brand new file, or with a specific project only?
Furthermore, I would like to ask which Archicad version you are using?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-20 07:00 PM
I use AC 24 on a MacBook Pro 15" 2019 and it tends to lag a little when using Trace Reference. It may not be AC25 on M1 Max. It may be a need for a Graphisoft refinement on Trace Reference?
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-21 05:49 PM
Hi. Yeah it always happen when I turn on Trace & Reference in brand new file. I am using Archicad 25.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-21 05:53 PM
Ive seen that on previous versions it had also lagging problem,but its lagging way too much on M1 Max. Feels like the program not enough upgraded for a new Macs ((
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-02-04 02:54 PM
Hi All,
Thank you very much for sharing the experience and I am very sorry for the issue!
From the investigation in another case, I found that: if you activate Trace&Reference while using a custom pen set, the performance can be quite bad. The reason here is that a custom pen set can cause unnecessary refreshes. Combining with Trace&Reference, it will cause some serious slowness. Also, tracing a saved view might also cause some slowness, as Archicad will have to display to different view settings on the plan.
Thus, I avoid having this combination in floorplan.
I hope this will give you some hints on the issue here. Feel free to ask if you have any questions!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-02-06 05:04 PM
FWIW I have the same spec Mac and 25 is working without any issues. Usually 4 ACs running at the same time and I don't see any lag on Trace/Ref. It is possible that there might be another reason for the slow down.
Try doing a New and Reset and create a new file using the GS template to see if it is something that was migrated. Also check that the Trace/Ref view you are using is simple and instead of linking to the one in the View Map use the one in the Project Map.
AC28 US/INT -> AC08
another Moderator
