2020-05-22
06:28 PM
2024-01-30
10:17 AM
Aruzhan Ilaikova
2022-01-03 02:42 PM
Thank you very much for the question!
May I ask, when you open Graphisoftid.graphisoft.com, does the browser load anything, or does an empty page appear (or even worse, no connection error appears)?
Happy New Year!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2022-11-01 04:21 PM
Ні, the same problem only on windows 11, can you make a post with a solution to the problem? We will be very grateful!
2022-11-01 04:51 PM
hello, I saw that you had the same problem with logging into grafisoft id, can you tell me if you found a solution?
2022-11-10 11:18 PM - edited 2022-11-11 08:33 AM
Hi, at windows 10 - problem was solved by advice from @Minh Nguyen
1 go to: C:\Windows\System32\drivers\etc
2 open Hosts (with wordpad or notepad)
3 delete all lines from # Graphisoft Anti-license checks by Up7 till the end. Once you're done, press Control + O to save the changes.
4 close editor ( Control + X )
d.m.
2023-02-09 02:46 PM
Hallo, I have the same problem. I have attached 2 screenshots of my terminal and licence manager tool. Please help:)
Thank you in advanced!
