Archicad crashes on start up
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-09-18 12:48 PM
2020-09-18
12:48 PM
PC runs windows 10 pro ver 2004 64bit,
cpu:Intel xeon E5620 2,4GHz
RAM: 6,00 GB
GPU: NVIDIA Quadro FX 1800
I tried unistall and reinstall, i talked with the reseller here in Greece and they have no idea how to fix it.
A week before, archicad was running fine on that particular PC.
Any ideas?
Labels:
- Labels:
Performance
14 REPLIES 14
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-10-12 10:43 AM
2020-10-12
10:43 AM
mnguyen wrote:I did a windows system restore, I reinstalled archicad and problem is resolved.
Hi Tim,
Thank you for the question!
Yes, it is true as Miha said, that this feature needs to be disabled. Could you give it a go and see if it helps?
Best regards,
Minh
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-10-12 08:33 PM
2020-10-12
08:33 PM
Thanks for all the replays,
mnguyen wrote:I tried both with it enabled and disabled, but it unfortunately doesn't seem to work either way.
Hi Tim,
Best regards,
Minh
3tp wrote:Ah, yes i guess this would be the last resort, but if nothing else works i'll try that.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-10-13 09:00 AM
2020-10-13
09:00 AM
Hi Tim,
I'm wondering if you keep any bugID of the crash? Normally, if the Bug Reporter shows up after a crash, a bugID should be created after you send the information to us (https://helpcenter.graphisoft.com/knowledgebase/64553/)
If you are on Archicad 24, here is the guide: https://helpcenter.graphisoft.com/knowledgebase/130130/
These IDs would be very crucial for identifying what triggers the crash!
Best regards,
Minh
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-10-13 01:47 PM
2020-10-13
01:47 PM
mnguyen wrote:I totally forgot to mention, I recieve an network communication error whenever I'm trying to send a bug report, so I don't have any ID's. For some reason archicad thinks that I'm offline, however I do recieve an (.rep) file, which doesn't get send.
Hi Tim,
Best regards,
Minh
Thanks for the link, I see that I'm supposed to send this file to our local provider, I'll do this immediately.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-10-13 02:32 PM
2020-10-13
02:32 PM
Hi Tim,
Yes, the REP file can be sent to your local partner for checking. Or, if you don't mind, you can drop me a private message and I will be very happy to check the crash report!
Thank you very much!
Best regards,
Minh
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
