Installation & update
Archicad
Arwen
Hi i take Archicad to try it for 1 month but i cant find the serial number. Where can i find it?
This is the wrong forum for this inquiry, but if you are using a trial you should have the serial number in an email I assume. Or a special download.
@SenecaDesignLLC  thanks for noticing this.  I've moved this from the Design Forum to the Setup and Licensing Forum where it belongs.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
