Installation & update
Can't install Archicad 18 in Mac OSX MOJAVE
Can someone please help? I clean installed MOJAVE in my macbook pro but the Archicad 18 installer doens't run and install...
Any workaround?
many thanks
1 REPLY 1
Not surprising, given the age of 18, although the Graphisoft tech article on Mojave suggests that it should be possible to install:
https://helpcenter.graphisoft.com/knowledgebase/84821/
You can install 18 on another Mac that has an older OS - and then copy the 18 folder from the Applications > Graphisoft folder of that Mac to your Mojave one.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
