DRAWING WALLS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2005-02-08
09:45 PM
‎2025-01-30
10:54 AM
Molinda Prey
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-02-08 10:06 PM
Grant
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-02-09 12:28 PM
After you type in your reference are you clicking on the screen, press enter or pressing r again. You should be pressing enter.
If you are talking about the reference line of the wall-
Make sure you wait for the correct cursor before you click. There will be a list of cursors in the help menu.
Julia
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-02-15 05:07 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-02-15 11:28 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-02-16 11:02 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-02-16 11:20 PM
jcude wrote:
i am using a typed reference and i am hitting enter instead of clicking with the mouse. exact steps: i click to start the wall, then press shift to straighten it out, i then press r while i am holding shift. i let go of all keys and type in the length of the wall that i would like. then i press enter. the wall stays the length that it had been dragged to by the cursor. it has gotten me all confused as to how it does it right sometimes and wrong other times. i hope this helps with the process of finding the solution.
Your mistake lies somewhere in here. Either...
1. hit Enter to start the wall (keep away from the mouse)
2. type x ( or y) and the length (or a and the angle then r and the length) you want the wall to be
3. hit Enter again
or...
1. click the mouse where you want to start the wall and begin moving the mouse in the direction in which you want the wall to go
2. press Shift to straighten it out, then press r while holding shift
3. type the length you would like the wall to be
4. hit Enter to complete the wall
By the way, working this way it's better to keep the "Delta" buttons depressed.
Woody
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-02-16 11:25 PM
You need to enter x coodinates and y coordinates. So to draw a wall 10 feet from left to right, start your wall and hit the X key, then enter 10, then hit the Y key and enter 0. ***Then you must hit enter to complete the entry. A mouse click will override these entries!***
This assumes that your delta button is indented for the x and y coordinates in the coordinate box, making these relative measurements.
An easier way is to start your wall, move your cursor to the right then simply to hold shift down to lock in your horizontal constraint, and hit the R key. Then enter 10 to define the radius of how far you are modeling your wall from it's origin. This also assumes that the delta button is indented for the radius.
Please see the attached animation for an example of the latter method. You'll notice that the 'A' (for angle)has a box around it, indicating it is locked as soon as shift is pressed. And as soon as you hit R, the R value is highlighted, ready to be overwritten. Hitting R again, will toggle this off, if you ever hit it by mistake. This should help you visually in the future.
Good luck.
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-02-16 11:38 PM
woodster
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-02-17 01:19 AM
jcude wrote:My guess is that you haven't gpot the numeric keypad turned on a
WHEN I DRAW MY WALLS THE WILL NOT SNAP TO THE REFERANCE ENTERED. THEY CONTINUE TO SNAP TO THE DISTANCE MARKED BY THE CURSOR. WHAT DO I DO?
ll the time!
