Installation & update
Desktop workstation considerations regarding Teamwork local data - second drive: HD or SSD?
Johan Stinckens
We are replacing one of the workstations in our firm and I have been quoted for two similar machines.
The one difference between them: the second 1TB drive is either a HD or an SSD.
Any ideas on this considering that we have recently moved more of our projects to BIMcloud.
The local copies of the Teamwork projects would either reside on a SSD or on a 7200rpm HD.
What performance improvements might we expect? Are these significant or not?!
Johan Stinckens
BIM Modeller at Atrium Architecten
Archicad user since April 2014 (v17 - v26) - CC iRT i9-12900 - 64 GB / Nvidia Geforce RTX 3080 - Windows 10 Pro 64
Other than that it's hiking, camping, climbing.
Marc H
I only use SSDs, whether internal or external type. Because they are solid state technology, they have fast read/write and no mechanical failure. If you utilize external type (for off-line back-up or mobility), you may want to consider independently encrypted models.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Lingwisyer
Guru
Will you be working off that drive? If so, the SSD will be a significant improvement.
