Double monitor_ FILES DONT OPEN IN AC 23
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-04-11 08:55 AM
ArchiCAD 23 crashes each time i have the double screen/ monitor option enables in my Windows parameters.
Files open when I have single monitor checked - but dont when I have double monitor ?
This is beyond annoying.....
Any suggestions whatsoever, no matter how silly, are welcomed..
thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-11 03:59 PM
If you are running windows 7, please bear in mind that all windows versions except 10 are not officially supported. Please read the page below:
System Requirements for GRAPHISOFT Products
macOS Sequoia
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-11 05:13 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-12 12:06 AM
Thank you for sharing your experience and I am very sorry about the issue!
From your description, it is difficult for me to find out what may cause the crash. I am wondering if you can share with me:
- The computer's specification
- The Bug ID of the crash
In addition, please make sure that you have the latest OS update, and please install the latest ARCHICAD 23 version (build 4006).
Thank you very much! Looking forward to hearing from you!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-21 01:26 PM
insideru wrote:Just get the windows 10 lol, windows 7 is pretty bagged with dualscreen stuff
We have 4 windows 10 pcs running ac23 at the office, all dual monitor. We have no problems whatsoever.
If you are running windows 7, please bear in mind that all windows versions except 10 are not officially supported. Please read the page below, detect history reviews.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-06-29 02:34 PM
In this case it's AC22 - I haven't tested AC23 on it.
The file will open fine on ONE monitor. It will crash (hang on generating any 3D view) on the other.
I have swapped ports on the graphics card, swapped cables, but it's the same result each time. Interestingly, I can open it on the one screen, then move the application to the second screen and it will work fine.
Maybe try move AC to the other screen and open from there to see if it's similar to my issue!
Specs for this machine:
- AC22 (7000)
- i9700 32Gb ram
- RTX 2070
- 2 x 4K monitors
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-06-30 02:20 PM
AlexM wrote:Hi Alex,
I'm having a similar issue with one of our machines.
- AC22 (7000)
- i9700 32Gb ram
- RTX 2070
- 2 x 4K monitors
Thank you for sharing the issue and I am sorry about the experience!
This "move the application to the second screen and it will work fine" really puzzles me. Usually, if the application does not work on one monitor, it should not work regardless of how we open it. I'm wondering if you can share with me the set up that you are using:
- Are you using laptop or PC?
- How do you connect your machine with the screens (do they go through a hub?)
- Do you have Intel GPU in your machine running along with the NVIDIA GPU?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-10 12:35 AM
It's a puzzling one for sure.
- This is full tower PC (Dell). We have other identical ones - users haven't reported issues on those. I haven't tested these in-person yet though.
- Screens are connected directly to the graphics card with Display Port cables
- The machine does have integrated graphics, but the system monitor shows Archicad using the main GPU (the RTX2070).
I haven't tried disabling integrated graphics completely, but I'll give that a go.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-10 03:05 PM
Thank you for the information!
This is quite strange...I'm wondering if you unplug the "good" monitor, and leave only the "bad" monitor connect to the GPU and start Archicad, does it still make Archicad crash?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-10 05:16 PM
atfonit wrote:Please update your forum signature to show that you are on Windows 10 then... it still says Windows 7 on all of your posts at this moment. (The signature is a database field... when you update it, all of your posts will update.)
No I am on W10, thanks anyway
