Extremely slow navigation times!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2003-12-05 05:26 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-12-05 06:31 PM
when you say that all computers are running 10.2.8, do you mean that the server is running OSX server 10.2.8 as well?
our office has a 1GHz X-serve with OSX 10.2.8, 512MB ram. 95% of the office machines are running 10.2.8 as well. whilst there is long wait for library load times and sending and receiving to large files, actually navigating the files and folders from within archiCAD dialogue boxes is as fast as all other apps.
does your network use a switch or a hub? what speed is it? are the files and folders that archiCAD is navigating in a different share point to files that the others apps may be browsing? are you running a RAID setup on the server, if so hardware or software RAID?
have you cleared out all archiCAD prefs and tried from scratch? once you have navigated to the file, does it save quickly once open, or does the slow down affect the actual opening and saving times of the files as well?
~/archiben
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-12-05 08:32 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-01-05 02:22 PM
We identified your problem with browsing network volumes in ArchiCAD open dialog. It seems to happen only with Mac OS 10.2 networks. It is either an OS bug, or there might be a problem with your DNS name resolving.
While we try to find a solution in ArchiCAD, please use this workaround: navigate to the desired folder in finder, then drag and drop the folder into the ArchiCAD open file dialog.
Upgrading to 10.3 will also fix your problem.
Sincerely,
Greg
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-01-06 03:48 AM
AC 24 (Full)
Mac Pro (Late 2013) OS 10.13.5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-01-08 05:22 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-01-08 11:38 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-03-17 04:58 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-04-24 01:31 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-05-14 09:58 AM
We are also currently testing PC's as a replacement to Macs because of these problems and parts of ArchiCAD that does not work on a Mac, and so far I have had no problems in terms of speed opening up files.
It would appear that Graphisoft have spend more time testing 8.1 on a PC than a Mac.
Stuart (Hitting the wrong shortcut keys on a PC.)
