Flashing in 3D modeling views
Gus
When I try to navigate (rotate, pan zoom, etc.) in 3D modeling views, it flashes my site plan. It's not the end of the world, but it is extremely annoying every time I'm working in any 3D view. Does anyone know why it might be flashing like this?
-Michael
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
11 REPLIES 11
Hello Gus,
Do you model near the origin ?
Do you have two elements at the same place ?
Can you share a screen capture ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
The first thing to do when you see some graphics anomaly is to make sure you have the latest graphics drivers on your system.
Yvonne
Is this the flashing you get?
I've recently noticed this in 3D views...
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
I noticed this during Beta testing for 24 and reported it at the time.
You will get a quick flash of whatever is in your 2D window.
I can't recall the outcome, and we don't have access now to the Beta reporting.
It doesn't seem to affect anything - just a little annoying.
I've started experiencing exactly this in 25 v6000. I assume it's a hardware issue but was there any conclusion to this?
JeffH
Is your Editing Plane display on?  That has caused some screen flashing or flickering for me in the past.
AC24 / AC26 / AC27
Win10
No, it happens with or without the editing display
Nathan P
This has started to happen to me across multiple versions of AC (our office uses 22-25). I was able to record this for AC 24 but it is persistent in those I have tested. Additionally, if a change is made to the view settings of the 3D window, it will jump to the last active 2D window almost like it is trying to regen.
Video of issue
To squash any questioning replies: yes my drivers are up to date, all system updates are in place, and all peripherals are updated as well.
This was not always the case for this specific computer, but we are in the process of testing how Windows 11 works with ArchiCAD as commercial sales are ending for Win 10 and support is dwindling across multiple platforms. This did start happening with the Win 11 upgrade but according to Graphisoft, they are supporting AC versions 25 and up for the Win 11 transition. It is unacceptable to have graphical lag impact performance and efficiency.
Has there been any fix for this? Are there even any constructive thoughts from GS? Has anyone heard anything other "update your drivers" from GS?
Any help would be greatly appreciated.
AC24.7000
AC25.6000
Laptop:   Dell Precision 7670
Processor:    12th Gen Intel(R) Core(TM) i9-12950HX   2.30 GHz
Installed RAM:    64.0 GB (63.7 GB usable)
System type:    64-bit operating system, x64-based processor
GPU:   NVIDIA GeForce RTX 3080 Ti Laptop
System:   Win 11 Pro | 22H2 | Build 22621.1105
Dear Nathan,
I had exactly the same issue and I had a hard time concentrating.
I finally solved it by uninstalling Archicad, but using iobit uninstaller.
The difference with uninstalling from windows settings is that iobit uninstaller erases everything, including registry records of the application.
I installed it again and it works great.
