Marquee is acting wierd / error [confirmed bug]
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-07-05 10:37 AM
2018-07-05
10:37 AM
After I have completed the rectangle, the marquee is displayed wrong, it still works, just the display is skewed.
In the attached screenshot the marquee is supposed to be parallel to the other elements.
Where should I report this?
arch. ernest atanasiu
AC 10-26 INT/GER/FR on Win 10/ Win 11
Solved! Go to Solution.
Labels:
- Labels:
Performance
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-10 05:15 PM
2018-07-10
05:15 PM
Hey Everyone,
I tried it, and it is indeed very easy to reproduce. I could even reproduce it in earlier versions, so it has been present for a while.
Anyhow, I added this to our bug list, we will see when we can fix it. Thanks for pointing it out.
Regards,
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
GRAPHISOFT
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-05 10:46 AM
2018-07-05
10:46 AM
uisanata wrote:This looks odd, the end of your marquee is not square.
More of a parallelogram rather than a rectangle.
I would make sure your video card drivers are up to date.
Also restart your machine.
If there is still a problem and you have a support agreement with your license, you will be best to contact your local distributor (support person).
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-05 12:32 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-06 03:28 AM
2018-07-06
03:28 AM
I am glad you mentioned the zoom.
It seems the longer the marquee is, then the lower the zoom factor is that will affect the angle.
It seems to have something to do with how much of the marquee is off the screen as you zoom.
So the more one end of the marquee goes off the screen as you zoom in on the other end, the more the angle of the marquee distorts.
I can reproduce this if that helps - but I can't say it will affect me at all - I have never noticed this till now.
I tested it in version 18 as well as 21, and it is there too, so it has been around for quite some time.
If it doesn't affect the outcome then I guess it will not be a high priority to fix even if you did report it.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-10 05:15 PM
2018-07-10
05:15 PM
Hey Everyone,
Regards,
Regards,
GRAPHISOFT
GRAPHISOFT
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-11 08:23 AM
2018-07-11
08:23 AM
Great, thank you!
dkovacs wrote:
Hey Everyone,
Regards,
