Installation & update
PowerPC AC7 file to Intel AC18 DWG
Ok, I have an old file made in AC4 that I brought up to AC10, but it is still running on an old PowerPC Mac.
How do I get it to be a AC18 file to run on an iMac and then eventually make into a dwg file to send to someone else.
I bought a floppy reader to read the old file, but unfortunately some of the old floppies are not longer readable......
thanks!
1 REPLY 1
AC18 can read (open) files back to AC8.1
But if your file is on floppy disk and you can't read the floppy then there won't be much you can do regardless of what version you have.
Can you open the AC10 file on your old machine?
