Installation & update
Problem in 3D Mode
Dear friends,
I work with Archicad for a long time and suddenly 2 problems appeared
First one is when i want to draw a morph in section plane i cant see any lines( creating lines) when drawing on surface.
Second problem i will upload as a photo, its not just with walls, it happens with all objects in 3d mode.
Thank you in advance.
PS Sorry for my bad english.
Erwin Edel
Looks like a bug possibly related to drivers for your GPU. Check if those are up to date.
You also get strange artifacts happening if you have your model very far away from the origin (0,0,0).
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Hello, have u fiex this problem. I have the same issue, but could not find a fix
See Adeon's post here ... https://archicad-talk.graphisoft.com/viewtopic.php?f=22&t=72781
Edited by moderator.
Podolsky
Ace
It might be graphic card. Please check articles about graphic cards on Graphisoft web-site.
