2010-08-02 06:07 PM - last edited a week ago by Aruzhan Ilaikova
2010-08-02 08:10 PM
2010-08-02 08:32 PM
2010-08-03 04:07 PM
2010-08-03 07:32 PM
2010-08-04 05:29 AM
2010-08-04 07:02 PM
2010-08-06 06:47 PM
Karl wrote:Duh. Graphisoft was on top of this some time ago. I just didn't read the Wiki article. See:
Thanks, Erika. Hopefully, they'll make a note of the issue on the Wiki, or else others will find this discussion during a search.
RequirementsSince the HTML code can check what browser is rendering the page, it might be smart for a warning to pop-up if anything other than the supported browsers (above) is in use.
To use the upgrade site, you need:
- a key that is eligible for upgrade
- internet connection
- a compatible WibuKey or CodeMeter driver installed (use the ArchiCAD install DVD to install the correct drivers. The drivers from wibu.com may not be compatible with the upgrade site)
- On Windows, Internet Explorer (other browsers are not supported)
- On Mac, Safari (other browsers are not supported)
- up-to-date Java environment (make sure operating system updates are installed)
2010-08-11 12:52 PM
