2020-09-25 09:31 PM
| Archicad 4.55 - 27
Solved! Go to Solution.
2020-09-30 11:01 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-09-28 11:17 AM
Minh Nguyen
GRAPHISOFT
2020-09-29 05:13 PM
| Archicad 4.55 - 27
2020-09-30 11:01 AM
Minh Nguyen
GRAPHISOFT
2020-11-22 04:49 PM
2020-11-23 03:08 PM
fabioferrini wrote:Dear Fabio,
Same issue here,
on Mac OS 10.15.7 AC crash randomly when I try to publish .BIMX; .DWG, very frustrating!![]()
Fabio
Minh Nguyen
GRAPHISOFT
2020-11-23 04:08 PM
| Archicad 4.55 - 27
2020-11-23 05:38 PM
mnguyen wrote:Thanks for your interest, mnguyen:
Same issue here,
Fabio
Thank you for the report and I am very sorry about the issue!
Is there a stable way to reproduce the crash? Also, does it happen even with a blank file, or with some specific files only?
I'm wondering if you keep a copy of the sent bugIDs? If not, all IDs of the sent crash reports are recorded in a file called SubmissionLog.txt. This file is located at:
On Windows 10: C:\Users\<user>\GRAPHISOFT
On macOS: <user home>/Library/Logs
With the bugID, I can run a quick check to see whether the crash is linked to a known issue.
Best regards,
Minh
2020-11-25 03:54 PM
Minh Nguyen
GRAPHISOFT
2020-11-26 12:07 PM
