Installation & update
Stairmaker add-on is missing
Hi, all. I'm a newbie, running AC21 Solo Build 5024. I'm not finding StairMaker in my add-on folder and I can't find where to download it online. Can anyone point me in the right direction?
Big thanks!
Bill
4 REPLIES 4
Eduardo Rolon
Stairmaker was substituted by the new Stair tool so the only way you will get it is downloading AC20.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Greg D
I cannot find the stair tool in v21. I have it in v20, but it is missing from the toolbox in 21. Any ideas?
Greg Danskin - Architect
http://www.danskinarchitecture.com
AC 19/20/21
iMac Retina 5K, 4 GHz Intel Core i7, 32 GB 1867 MHz DDR3, AMD Radeon R9 M395X 4096 MB
OS 10.13.4 High Sierra
Eduardo Rolon
Check your work environment settings.
AC27 US/INT -> AC08
another Moderator
If you are using a Work Environment that has been imported from an earlier version of Archicad, then you may be missing all the new commands from your toolbars and menus.
So either start with a new default WE and then add your own customisation back to it, or use our old imported WE and add the new commands to it.
