Installation & update
Steni Facade Tool - Install issues.
AteArchi
When installing the Steni Facade tool to my Archicad 25 I am met with "Failed to copy system settings file to: /users/username/documents/stenifacadetool/steni_Settings.xml
Can anyone shed some light on this please? I am installing it as you would any other add-on via an Archicad 25 bundle.
Thanks
You will likely need to contact the creator/distributor of the add on
Lingwisyer
Guru
Make sure you have permissions. Try running the installer as admin.
Morten K
I have the same problem. Did you figure it out?
