Text Tool -Problems Editing
Jacek
Does anyone have a problem with the Text Tool in AC 8.1?
I have opened a drawing (open archived) from 7.3
Tried to edit a text box; selected it and when I klick inside the box to insert the cursor the box disappears!
It is Gone! Blank! Kaput!
I have to klick somewhere else for it to come back.
The only way to edit the text, is to do it blindly, typing 'in the blank' and then klicking outside the box to see if it is there and in the right place. -Not a very good way to place notes....
I am also unable to start a new note and see the type, same thing happens.
Has anyone gone thru this?
Heeelp!
- Back to the drafting board...
Jacek
jacek lisiewicz
arkhos-tekton, architects
carmichael, ca
Mac OS X 10.15.5
IMac Retina 5K, Intel Core I7
32 GIG Memory, AMD Radeon R9
ArchiCAD 24
10 REPLIES 10
Aussie John
some odd things happen with the text blocks. Im not sure if it has been fixed in 8.1
Cheers John
[/size]
Jacek
8.1 seems to be the problem, unless it is just another peculiarity of my personal setup again..
Hadnot experienced this in the previous version.
So for now: Cleaned up the drives,
Checked the fonts
Repaired privileges (??)
Opened up couple of other files to check -same #%$%
Restart, and hold my thumbs
- will report results, if any...
Jacek
jacek lisiewicz
carmichael, ca
Mac OS X 10.15.5
ArchiCAD 24
I have ocassionally experience the same. Not as drastic. Try zoom in or out and select the text block again.
This is off course absurd and I dont know why it work.
Conrado
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
Jacek
Conrado
..that makes sense...
seems like I am spending half the time trying to figure out the quirks of the software and the other half workarounds the bugs..
One forgets that it is all in the name of efficiency and time saving, moving with the technology? (!)
I will try that...
I have nothing to loose.
Jacek
jacek lisiewicz
carmichael, ca
Mac OS X 10.15.5
ArchiCAD 24
Jacek
OK.
so I might be acused of posting gratuitous questions/replies, but what the heck! I am feeling good, I am on the roll now...javascript:emoticon(':)')
So I tried a few things, rolled with the punches, got up and tried again....
In a moment of desperation i remembered the old "New and Reset" trick, what the Hell, tried it. .......
...........It worked!
OK, feeeling goodand haughty from the recent success, I tried the erroneous file again and..... It WORKED!
..as I always said, don't panic, have a glass of wine, or two and try something you have not dared to, or forgot how, -again.
Ha!
jacek lisiewicz
carmichael, ca
Mac OS X 10.15.5
ArchiCAD 24
Jacek
Spoke too soon.
The bug came back again!
Did everything as decribed earlier and it did work. I did some snooping and I have found out why:
The "New and Reset" solves the problem because it resets the preference to "Optimize 2D Redraw for Open GL" to "OFF"
With the Redraw optimized to "ON" the problem with the text tool returns. Now I do have what at some point was considered a high speed GL card -see signature below, so I don't know why is the problem surfacing now?
Another thing; one can not access the preferences with the Text tool selected in the toolbar, I don't remember that in 8.0 -perhaps it was there and I just did not pay attention.
...........It worked!<
jacek lisiewicz
carmichael, ca
Mac OS X 10.15.5
ArchiCAD 24
I haven't found the OpenGL for 2D redraw to be much help (even with high end video cards) and it definitely seems to be a bit troublesome. I recommend leaving it off.
Djordje
Ace
... which is where I would leave it.
Use OpenGL in 3D window, in 2D I have not seen any advantage of using it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
__archiben
it certainly makes a difference to a couple of our bigger jobs in the speed of navigating around. i tend to keep it on, and advise the others here to do the same.
as you say matthew, it can be a little troublesome, (screen white-outs, selection dots disappearing . . .), but i have learnt to ignore them as the benefits for me outweigh navigating without it.
~/archiben
b e n f r o s t
