The application “ARCHICAD 26.app” can’t be opened.
hpenbeoglu
I'm getting this error for all versions of Archicad as soon as I start the application. If I update or reinstall, it works, but it comes back again. Recently, I was trying to install the Goodies addon. However, that also didn't work. I thought maybe these two were related and uninstalled the plugin but no luck. Any idea?
BIM Manager, Architect in the UK | AC11-AC27
Macbook Pro 16" 2.4 GHz 8-Core Intel Core i9 - 32 GB RAM - 512 GB SSD | MacOS 13.3.1 (a)
6 REPLIES 6
runxel
Hero
I have a similar issue. Support told me to make a new user profile on the mac. That seemed to work. (Other than that the support was useless, they refused to submit the bug to Budapest....)
However instead I just now rightclick Archicad > "Show package content", then find the Archicad Starter executable and voilà, it comes up. Everything works. Which makes it even weirder.
Lucas Becker | AC 27 on Mac | Graphisoft Insider Panelist | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
@hpenbeoglu and @runxel  - your signatures don't indicate your version of macOS.  Could you confirm that you are both running Intel and presumably Ventura 13.3.1(a)?
If a new user profile works, it would seem to be an issue with a preference file and/or possibly firewall settings (although I thought Mac firewall settings were global across all users).  Let's see if anyone else has some ideas...
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
hpenbeoglu
@Karl Ottenstein. That's correct. It is Intel and MacOS 13.3.1 (a)
No, it's an M1 MacBook with Monterey for me.
I used the preference cleaner, so there must be something else involved.
What is preference cleaner?
dnathanc
Same ongoing issue for me with A26 - MacBook M1 Pro / Ventura 13.4.
Restarting has taken care of it so far, but that's pretty inconvenient when you have a bunch of other apps and content running.
