Installation & update
To change the language
Gulshan45
I have installed Archicad, but it is in Egnlish, I need a Russian language version, how can I get it. I would much appreciate for your help. Many thanks
4 REPLIES 4
What type of license do you have?  If a commercial license, you will have to contact the Russian distributor for the RU version.  If an educational license, then you will have to go to your Account settings on myarchicad.com and complete your registration using a Russian address.  I believe that address is how the site determines which version to offer you for a trial or educational license.  Not 100% sure though.
One of the forum moderators
AC 26 USA and earlier   •   macOS Ventura 13.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
see also:  https://graphisoft.com/ru/solutions/archicad
Inga898
Hello! Please, can i change the language to russian? Best regards, Inga
Karl has posted the solution already.
Versions 6.5 to 25
