2020-09-23 12:11 PM - last edited on 2024-01-29 02:27 PM by Aruzhan Ilaikova
> ARCHICAD-24-GER-3008-1.7.exe --help
--mode <mode> Installation mode Standard: win32 Zulässig: win32 unattended Zulässig means valid, allowedIs this still accurate?
> ARCHICAD-24-GER-3008-1.7.exe --mode unattendedand it seems it installed AC24 as 64-Bit (is there an 32-Bit Version at all?).
Solved! Go to Solution.
2020-10-07 02:17 PM
SeRohde wrote:Hello,
LaszloNagy wrote:I can only describe it for the Windows Installer. It's a popup. After reading about unattended install methods in the helpcenter I wanted to try it out and maybe write a script for my company.
Where is this 32-bit info? Is this in a GRAPHISOFT file? Can you tell me where? I could then forward it to GS HQ so they can fix it.
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-09-23 02:00 PM
2020-09-23 09:36 PM
2020-10-06 01:27 PM
2020-10-06 06:46 PM
2020-10-07 02:17 PM
Minh Nguyen
GRAPHISOFT
