Read more
Installation & update
Wibu Key and Multiple Users
Currently have ArchiCAD 12 installed with the USB dongle and was wondering if there's any config change I need to set up on the WIBU key manager in order to allow other users to use the software without inserting the USB dongle?
Do I need to get the network share USB dongle or will this standalone one work? Of course, only one user will be able to access it at a time. Thanks.
See this:
http://www.archicadwiki.com/Wibu%20key%20Server%20Basics
and, if you want internet access, this:
http://www.archicadwiki.com/TechNotes/Example%20of%20Using%20Wibu%20Key%20Over%20The%20Internet%20wi...
Sharing a single-license WIBU key worked fine on my network between Mac and PC until a few months ago. Not sure what I messed up, but when it works, it is easier than moving the dongle around.
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.7, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks. After messing around with it, I think we'll need a network WIBU key dongle in order to have it work with Multiple users.
I had just the WIBU server component loaded on a test machine and the full client loaded on another system. After pointing the WIBU settings on the client system to the server, it sees it, but could not issue a license so the software started in demo mode.
I get the following error message on the server log:
Logon received from "ACRobur2156" at SERVER_NAME.
Cluster 1861:398085 not found.
