2022-03-27 09:23 AM
I was using Archicad 23, I had removed it from the laptop before. .bak file was giving an error I changed the .bak file extension to .pln file, it gives an error that the plan file cannot be read, what should I do now?
2022-03-27 03:36 PM - edited 2022-03-27 03:38 PM
Read this helpful guide prepared by @mtron and edited by @Rubia Torres
2022-03-28 06:12 AM - edited 2022-03-28 06:17 AM
.bak? Not .bpn?
Are not .bak files only generated during the save process and removed after? If AC died mid save I would assume that the .bak file would be incomplete and hence most likely unreadable...
Ling.
Win10 | R5 2600 | 16GB | GTX1660 |
2022-03-28 10:33 PM
I agree with Lingwisyer, a BAK file is not an Archicad Project Backup, you need to look for a file with the same name as your project and having the BPN extension.
