- 5 people are using archiCAD v16 connected to a network key
- 1 person using v11 with a local usb dongle
problem is… the user using v11 often takes a network key when Ist launching archiCAD… which obviously means there is 1 less key available for v16 users
is there anyway to force the v11 user to ONLY use the local dongle and not have them fetch a network key
i always thought that archiCAD looked locally for a dongle before looking for a net key
Yes, there is a way. But, it depends on what kind of dongle - WIBU (blue plastic) or CodeMeter (silver) - and what operating system the v11 user is using.
AC 28 USA and earlier • macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
unfort this machine is also used sometimes to connect to the key server to run v16… so i believe it has the codemeter drivers installed… as well as the v11 enabler
is there anything i can configure for it to default to the local wibu when launching v11 and the net key when launching v16
