Read articles about program installation and update, hardware, operating systems, setup, etc.
Articles
Archicad for Apple silicon
Great news for Archicad users! As announced at the Archicad 26 Launch Event, we are pleased to share with you that Archicad 26 is running natively on Apple silicon. The full commercial version, with all functions of Archicad 26, was released on the 2...
3rd party installers for GRAPHISOFT products
In this article, you can find a list of additional software needed for installing or running GRAPHISOFT products. When you run the installer, it will automatically install those third-party products which are not yet installed, or which are out of da...
mtron Graphisoft | Graphisoft
  • 25846 Views
  • 8 comments
  • 1 likes
Important Steps for BIMcloud / BIMcloud Basic Customers After macOS is Upgraded to macOS 10.15 Catalina
Affected version: BIMcloud 2019.4 Apple changed its security settings to enhance data security for its customers. As part of this progress, applications installed on macOS 10.15 Catalina and above must secure the user’s permission to access data. To ...
wp-content_uploads_2019_10_FDATool-3.png wp-content_uploads_2019_08_FDA_server.png wp-content_uploads_2019_08_FDA_manager.png wp-content_uploads_2019_08_FDA_deltacache.png
Archicad Installation
You can download the latest version of Archicad on graphisoft.com/downloads. Installation and startup troubleshooting guides Archicad 25 Archicad 24 Archicad 23 Archicad 22 Archicad 21 BIMcloud installation and configuration Educational Version Advan...
wp-content_uploads_archicadwiki_install--install.png wp-content_uploads_2016_06_giant-apple-logo-bw-232x300.png wp-content_uploads_2016_06_Windows_logo_–_2012_dark_blue.svg-e1529071408852.png
Getting Started with Graphisoft BIMcloud Basic
Related versions: BIMcloud Basic 2024.1 and newer This article will guide you through the BIMcloud Basic installation and configuration step by step with some additional information. Before Installing Checklist for installing BIMcloud Basic in the lo...
Java for ARCHICAD
Java versions that are supported by the GRAPHISOFT installers (or un-installers) In many cases newer, older, corrupted Java versions may block the installation and uninstallation of the GRAPHISOFT products. From here you can download the Java version...
Archicad silent install methods
Archicad Network Installation (Install Archicad as BIM Manager) Starting with Archicad 22 the standard installer for Archicad and GRAPHISOFT Add-Ons can be deployed in unattended mode. For details please consult the Install Guide for Archicad. Archic...
“Can’t find/choose instance.” warning while upgrading BIM Server to BIMcloud on macOS 10.13 or newer
Affected version(s): BIM Server 19, 20 and 21 | Severity: workaround applicable | ID: #229604 Issue Upgrade process of BIM Server v19, v20 and v21 to BIMcloud v21 will warn you on macOS 10.13 with “Can’t find/choose instance.” message. Workaround You...
Graphisoft Shell Extension
WHAT IS THE GRAPHISOFT SHELL EXTENSION The Graphisoft Shell Extension is a utility which modifies your Windows shell in order to display the preview and the summary of the contents of Graphisoft related files, for example Archicad project and library...
  • 3711 Views
  • 0 comments
  • 0 likes
Deployed Installation
This is an outdated article. For current deployed installation steps, please check our user guide. What is Software Deployment See details at Wikipedia. Deployed installation of update packages On Windows platforms you need to use the MSI package ava...
wp-content_uploads_archicadwiki_moniker-images_icon-info.png wp-content_uploads_archicadwiki_deployinginstallationpackage--clickonsoftdistpackages.png wp-content_uploads_archicadwiki_deployinginstallationpackage--newpackagewizard.png wp-content_uploads_archicadwiki_deployinginstallationpackage--newpackagesetpath.png
Installation Package creation for Archicad 20
Archicad Network Installation (Instructions for BIM Managers) With a Commercial and certain Education licenses, GRAPHISOFT offers you the option of creating an Installation package that contains your company-standard settings. Using this installation...
wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_ac20_gettingstarted_DefaultsBegin.png wp-content_uploads_ac20_gettingstarted_1_InstallGuide.1.22.02.png wp-content_uploads_ac20_gettingstarted_1_InstallGuide.1.22.03.png
Gatekeeper
Gatekeeper – Security & Privacy Gatekeeper is built in Security option from OS X Mountain Lion on that prevents you from running potentially harmful applications. You can access its settings: Open System Preferences Security & Privacy General tab All...
wp-content_uploads_archicadwiki_osxmountainlion--gatekeeper.png wp-content_uploads_WkUninstall.png wp-content_uploads_CmUninstall.png wp-content_uploads_Screen-Shot-2014-12-02-at-13.46.07.png
  • 2547 Views
  • 0 comments
  • 0 likes
QuickTime
GRAPHISOFT used QuickTime, Apple's multimedia environment in legacy ARCHICAD versions. See how different ARCHICAD versions used QuickTime's technology's in detail below: ARCHICAD 18 and newer ARCHICAD 18 & newer doesn't install or use QuickTime. ARCH...
Hardware and software considerations
System requirements Official system requirements on GRAPHISOFT home page: BIMcloud 20 and BIM Server 20 BIMcloud 19 and BIM Server 19 BIMcloud 18 and BIM Server 18 Recommended hardware for GRAPHISOFT products: Recommended hardware on Help Center Oper...
