3D window with aluminium sill - not right
Hi I'm struggling with Windows I'm trying to do it right but I cannot figured out.
I need window which is opening inside and have aluminium sill and I get this.
This is obviously not right do you know what i'm doing wrong ?
I set window with sun going outside and opening in side. I could find any setting how can i extend or move the window sill
Skärmavbild 2023-04-25 kl. 08.49.44.jpgSkärmavbild 2023-04-25 kl. 08.51.05.jpgSkärmavbild 2023-04-25 kl. 08.50.44.jpg
Other question what I don't understand
If I open this window in 3D I get this
But in 2D looks like this 🤦‍♂️ I don't get it
Thanks for any advice
I'm working in AC25 in SWE vesrion
AC 7 - 27 SWE
iMac (Retina 5K, 27-inch, 2020),
3,6 GHz 10-Core intel Core i9, 64 GB 2667 MHz DDR4, AMD Radeon Pro 5700 XT 16 GB
Miha_M
Try to adjust the frame thickness in the red circle (1.) and/or shift the window leaf towards the window frame (2). Windows in my region don't have such a huge gap between the frame and leaf edge, example here:
The distance you are missing (in green) is the inner side of the window reveal, which you can control, but only by controling the outer reveal size.
| Archicad 4.55 - 27
7 REPLIES 7
Miha_M
I don't understand the language in your settings pictures, but I think your window frame thickness is the problem. The sill is formed on the edge of the window frame, but you window has a very thick frame, which leaves a big gap between the sill and the window leaf.
| Archicad 4.55 - 27
This is Swedish.  I tried to find this setting(frame thickness) but i couldn't find out where is it
AC 7 - 27 SWE
I minimized frame thickness but still I don't think this is right how this should look like.
Do you know how to make smaller the window frame ? It's lock on 20 mm
Skärmavbild 2023-04-25 kl. 10.12.22.jpgSkärmavbild 2023-04-25 kl. 10.20.46.jpg
AC 7 - 27 SWE
That object seems broken for what you want, unfortunately I don't have an answer.
I did want to point out the "Missing" element is part of the wall thickness and is adjusted by the Reveal depth setting, which is common to all opening objects e.g. the inset from the wall face to the face of the window.
You may already know this, but I thought it might help.
Thanks, I'm just scare that I have 60+ windows with fail 😕
Anyway thanks for explaining.
AC 7 - 27 SWE
Miha_M
| Archicad 4.55 - 27
You are right 👍 Thanks I sett 20-50mm and looks much better.
Big thanks 🙂
Skärmavbild 2023-04-25 kl. 13.05.39.jpgSkärmavbild 2023-04-25 kl. 13.06.06.jpg
AC 7 - 27 SWE
