Got a minute? We appreciate your feedback:
Graphisoft Learn survey
ASSOCLP_NAME
DGSketcher
Legend
Is there a substitute for the following in AC21 GDL...
n = REQUEST ("ASSOCLP_NAME", "", name)
The request as shown has been phased out. I am trying to obtain the library part name to display in a label but can't find any meaningful guidance in the documentation or GDL centre.
Apple iMac macOS Sonoma / AC27UKI (most recent builds)
Gergely Feher
I tried it with the INT version and it seems working in 2D script. In other scripts it should not work, and it is written on GDL Center: "Expression returns 0 and contains dummy return values (emtpy string or 0) if used in parameter script, causing additional warning."
In which script did you try it?
_________________
Gergely Fehér
Team Leader, Library Team
GRAPHISOFT SE
DGSketcher
Legend
Hi Gergely, If this still works in the 2D script then I just need to debug my script.
I have not read the advice in the GDL centre properly which I now see refers to Parameter Scripts.
Thank you for the response.
Trevor
wilson83
What is the alternative for using ASSOCLP_NAME in the master/parameters script? I am trying to create a values list based on a library part name and the values list can only be generated in the master/parameters script.
Michael Wilson
ArchiCAD 9 - 22 (6021 AUS Full)
Win7 | 64 bit | 8Gb RAM | Intel i7 3.40 Ghz
