2016-02-0411:38 PM - last edited on 2023-05-2412:30 PM by Rubia Torres
Hi, does anyone know of a Bi-fold window object for ArchiCad 18. I know I can use a bi-fold door but then how do I get it to appear in the window schedule?
If you can get the bifold door to look like the window you want, you could convert it to a morph and then create a window object from the morph. You would have to add a wallhole to the gdl script to cut the wall, but it should work.
Thanks for the help. I've never used the morph tool but I'll give it a go. Using the bi-fold door & adjusting the schedules is also an option. Wouldn't it just be easier if ArchiCad had a bi-fold window object?
You can use a bi-fold door to present a bi-fold window.
In the tags & categories
Choose your ID to read window reference
Choose element classifications to window
In window list scheme setting add element type is a door reading the ID you choose
