2024 Technology Preview Program
Breaking Long Code Lines
How do you break a single long line of code into several shorter lines? In Visual Basic you can put an underscore character at the end of one line to tell VB that the statement is continued on the next line. Any equivalent in GDL?
7 REPLIES 7
It depends on what is making your line long. You can always put a return (line feed) after a comma. I don't think you can break up a formula (i.e. return after a `+` or such). You might be able to return after `&` and `OR` conditions. I don't recall if I've tried this or not but I think the comma is the only line continuation character.
The short answer is to add a return/line feed and see if an error results.
Also (I guess you allready know this, but...) the colon ":" symbol is meant to combine 2 lines into 1, so replace it with a return.
I doubt that's the problem, but you never know.
It's a mathematical equation. Neither the comma nor the colon work. Oh well.
Try splitting the statement like so:
x = 5 + 20
x = x + 25
And so x becomes 50. It's an option
Daniel Lindahl
Jay wrote:
How do you break a single long line of code into several shorter lines? ....
Jay
From the GDL manual, Chapter 2, section on character strings:
\new line continue string in next line without a new line
I don't know if this works - have never tried it.
cheers
Daniel
Daniel Lindahl Architecture
AC24 | Dell Inspiron 16+ | Windows 11
Daniel ,
I have some code with some very long "if....then" statements
with lots of "and"s and "or"s that had to be on one line or I
would get error messages if I tried to use commas but
I just tried your suggestion of using the backward slash character
"\" new line to break up the statement into several lines
and I get no error messags.
Thanks for the tip.
Peter Devlin
I tried the backslash in the middle of a very long mathematical statement and it worked just fine.
