Cabinet Wall Single Door, Door Thickness
In the properties of this object, I can set the thickness of the door, but no matter what I set it to, the 2d drawing does not reflect that. Is it supposed to reflect that and is it somewhere else I manage this?
Can I somehow look at the object itself how it was constructed in some way?
David Maudlin
famadorian:
You are correct, the door thickness parameter does not affect the 2D Symbol. You can open the library part by selecting it and using the command Open Object.... The Door Thickness variable is fr_th1. You can then look at the 2D Script to see where the door thickness is drawn and change it from a hardcoded value to the variable. This may impact other aspects of the symbol, so debugging may be required. This will take some basic knowledge of GDL.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Does the object have an option for a 'Detailed' plan view rather than a 'Simple' view?
I have noticed some objects sometimes have this option and it may alter how accurately the door is represented.
