Dimension objects in schedules
Dave Seabury
Is it possible to script an object so that when scheduled it would auto dimension like a window or door?
AC 19-24 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
4 REPLIES 4
I'd be guessing you would have to save you object with a window or door subtype. Then it will no longer work with the object tool and must be placed in a wall. The width of the 2D opening is what will be dimensioned.
Dave Seabury
I thought that might be the answer.
Thanks,
David
Jochen Suehlo
I think you can script dimension lines in your object so that the dimension are shown in the list in 2D or 3D.
Jochen Suehlo . AC12-27 . MAC OSX 14.4 . WIN11
Sorry Dave,
I was thinking about the automatic dimensioning in plan.
Don't know how I missed the scheduling side of things.
Here is a link to an old post about getting the auto dimensions for doors/windows in schecdules.
http://archicad-talk.graphisoft.com/viewtopic.php?t=30408
The hotspots need to be positioned based on certain parameter values.
Most of these are specific for doors and windows but some might be able to be used in other objects.
Maybe you could used hotspots based on parametrs such as "ac_unit_width", "ac_unit_height"?
I couldn't say for sure without experimenting.
Hopefully that link may shed some light on the subject and maybe will help you to head in the right direction if it is possible and sorry I may have mislead you in the first place.
