Door leaf undercut
David E
I generally size door openings via their leaf size as this is how I generate my door schedules, however I have issues with the ‘leaf undercut’ setting in the door parameters. Traditionally with undercuts I would expect the value of this gap to be added to the door leaf rather than taken off i.e. the wall opening size increases to take account of the whole door being lifted up to accommodate the floor finish.
Where is there a  "leaf undercut" setting ? I don't think I have seen that.
Leaf Undercut is an option you can find in settings panel for some types of doors but i think it's not available in USA version, see this post:
https://community.graphisoft.com/t5/Design-forum/ArchiCAD25-Door-Leaf-Undercut-Parameter-not-availab...
AC 27 INT 5003 - AC 26 INT 6019 ( For MEP Purposes )
In France we are able to cut each door leaf 5cm upper the floor with this parameter : 
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
