Electrical Objects
Destilat Design
Is there a library for electrical objects that are 3D modelled and have the correct electrical symbol in the floorplan? I just want to place one object and has the right 3D display in my section and just the electrical symbol in the floorplan.
I am working with ArchiCad 26 on macOS Big Sur.
Thank you in advance.
Jere
"correct" symbol is hard to define, but Archicad's built-in objects are somewhat ok. They work decently for receptacles and switches, but I find I often still have to do 2D work like adding extra text. The GFCI symbol, range symbols, etc. don't really match the standard in my area. And it's a relatively limited set of symbols.
But the 3D portions of the objects are good (though a touch inconsistent with entering height data)
ArchiCAD 26-5002; Windows 11; Intel i7-10700KF; 16GB RAM, GeForce GTX 1660
-translation-
Can you share?
Podrias compartir conmigo ese objeto?
@Javier Alvez Post have to be in English.
Those objects are part of the standard AC Library so check there.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
